Activity Forums Apple Final Cut Pro Legacy Tech specification
  • David Bogie
    May 12, 2009 at 8:04 pm
    go to apple.com, look at the specs for FCS2. Print them.
    Look at the specs for the mini. Print them.
    Compare.
    bogiesan
  • Kent Stipp
    May 12, 2009 at 8:05 pm
    Just be aware that while the Mac Mini MIGHT be able to run FCS 2 Apple will not support you if you have issues with running FCS 2 on a mac mini
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
