Activity Forums Adobe After Effects Tech question
  • Tech question
    Posted by Justin Giudici on December 25, 2007 at 12:23 am
    I have came to the decision to purchase the new Imac with the 2.4 processor. I was wondering if anyone has used this for after effects and what they think about it. I was considering upgrading the processor to the 2.8 but I really don’t know if its worth it. If anyone can give me suggestions on if I should look at something else. At work, I work on a G5 2.5 I forget what video card is in there. Any help would be great. thanks.
    ( I know people have a mac vs. win agenda I use both but I like the layout of mac and I enjoy final cut so there you go.)
    Brendan Coots replied 18 years, 8 months ago 4 Members · 3 Replies
  • Darby Edelen
    December 25, 2007 at 5:00 am
    The only thing I would recommend is: get CS3 before you go Intel Mac. If you already have CS3 then you’re good to go!
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • David Bogie
    December 26, 2007 at 5:10 pm
    This is rumor only, but we expect future versions of After Effects to start using much more of a graphics card’s processing and memory, much like Apple’s (incomplete implementation for) Motion. The iMac does not offer the ability to upgrade card or to add a second card.
    bogiesan
  • Brendan Coots
    December 27, 2007 at 11:26 pm
    The power this machine offers should be fine for most jobs. As Darby mentioned, get CS3 before buying an Intel Mac but other than that you should be fine.
    I personally don’t like the iMacs because:
    – It locks you into one monitor for good. Want bigger? Too bad. Have some bad pixels? Too bad. Monitor dies? Too bad.
    – Upgrade options are slim. Can’t upgrade video card etc. since they are part of the motherboard. As a result, you will be permanently stuck at the 2007 level of technology. Also, if the video card/GPU dies, you have to replace the entire motherboard at considerable cost. Also, the iMacs only support as much RAM as the macbooks (4GB). Given that AE and most video apps need as much RAM as possible, this could end up holding you back, and it will definitely prevent you from taking full advantage of the new multi-core processing features in After Effects CS3.
    – Virtually no add-on potential, such as a Blackmagic card for video monitoring.
