Activity › Forums › Boris FX › Tearing on BCC cylinder effect
  • Tearing on BCC cylinder effect
    Posted by Tom Kaemmerling on March 1, 2010 at 2:07 pm
    Used BCC cylinder effect on 3 images. The effect is the same on all the images except the final “landing” location.
    Image 1: 720 x 486 TIFF image @200dpi – no problem
    Image 2: 720 x 486 TIFF image @200dpi – no problem
    Image 3: 720 x 486 DV video – no problem
    Attemping to add:
    Image 4: 720 x 486 TIFF image @200dpi
    Copied and pasted the effect, but changed final placement location.
    Image “tears” at the edges. Image does not tear until rendered. Tried
    using a JPEG image and tried re-booting with no change.
    Any ideas?
    Peter Mcauley replied 16 years, 7 months ago 2 Members · 1 Reply
  • Peter Mcauley
    March 2, 2010 at 3:11 pm
    Hi Tom,
    You might want to pass this through our support group to see if this is something they have seen or heard of before. They should be able to assist you in resolving the issue. You can contact them via email at support@borisfx.com.
    Cheers,
    Peter.
