Activity Forums Boris FX Tearing an image in half
  • Tearing an image in half
    Posted by Caton Clark on January 15, 2010 at 4:22 pm
    I want to create a transition that appears to rip an image in half (i.e. like someone ripping a piece of paper).
    I’m working on an Avid MC3 system with BCC AVX 5.0.
    Anyone ever try to create this?
    Matt Mullen replied 16 years, 8 months ago 2 Members · 2 Replies
  • Matt Mullen
    January 15, 2010 at 5:29 pm
    If you have Boris Red or Avid FX there is a preset that is very similar to what you are looking for.
    In the library browser go to the Red keyframe library> transitions> DVE transitions> Page turns
    Check out the preset 2 better than 1.
  • Matt Mullen
    January 15, 2010 at 5:41 pm
    The other way I could think about doing it manually in Avid would be to cut 2 instances of the outgoing media over the incoming.
    Crop the outgoing so you have the left right or top bottom between the two layers. Then apply BCC Page Turn and set to your liking.
    Hope that makes sense.
