Activity Forums Maxon Cinema 4D team render & Xrefs
  • team render & Xrefs
    Posted by Sven Bombeke on May 31, 2016 at 11:22 am
    Dear, if I use team render and there are xrefs in my file then there are missing pieces of image in my visual … or sometimes the render just does not render at al. The team render starts and then stops after a few seconds … I’m only just starting using Xrefs. The Xrefs are all grouped together in a folder on our server. I find very little information about this problem …
    When i render without team render there is no problem, when i delete the xrefs there’s no problem also.
    can someone help me?
    greetings
    Nick Smith replied 10 years, 1 month ago 2 Members · 1 Reply
  • Nick Smith
    June 8, 2016 at 1:42 pm
    My guess on this would be the file size. Team render drops out if the file is too large to send over a network.
    In the preference settings there is an option to change that drop off point, but you’ll have to change that on all the machines in your team.
    Hope this helps!
    Nick Smith
    “So long, and thanks for all the fish.”
    http://www.anarkyanimations.co.uk
