Activity Forums Maxon Cinema 4D Team render without host???
  • Team render without host???
    Posted by Steven Burnham on May 7, 2021 at 1:51 pm
    I have recently “upgraded” my OS to Big Sur which has devastated my render times in C4D R20. I can Team render to machines running older OS, which render quickly but the host mac running Big Sur renders extremely slowly compromising my output. A test rendered frames at 27secs per frame on the client machines, running Catalina, but the host is 16mins per frame running Big Sur. My question is, can I team render from the host, without using the host machine to actually render any frames?? I can’t see any obvious options to do this from the render queue, so I’m not sure if it is possible. Any help would be much appreciated… Many thanks in advance!
    Cullen Burnett replied 4 years, 12 months ago 2 Members · 1 Reply
  • Cullen Burnett
    May 7, 2021 at 2:27 pm
    What render engine do you use?
