Activity Forums Maxon Cinema 4D Team render weird output
  • Team render weird output
    Posted by Mohsen Amini on November 27, 2018 at 6:47 pm
    hey everyone. when im using effectors, for example, to build up a structure and when I do team render with 4 computers it makes some mistakes in output. maybe because of those delay springs I used, computers cant calculate the way they suppose to? normal render with local pc is fine :/ I attached both outputs. this really slows me down. in scenes with delay effectors, I can’t use team render and should only use the main machine 😐
    thanks, guys.
    12912_correct.mp4.zip
    12913_wrong.mp4.zip
    Mohsen Amini replied 7 years, 9 months ago 2 Members · 4 Replies
  • Brian Jones
    November 27, 2018 at 7:31 pm
    try using Mograph Cache tags for cloners with dynamic type effectors on.
  • Mohsen Amini
    November 27, 2018 at 11:48 pm
    well every time I try something to improve my workflow in c4d something worse happens ???? it took 5 mins to cache all of my clones and c4d file is 3GB now :)) and c4d took 8GB of Ram and thats all I have, so very laggy and can’t do anything. anyway ill try to get it somewhere. Thanks man ^_^
  • Brian Jones
    November 28, 2018 at 3:58 pm
    it looks like only the last set of clones are the problem, are you caching only those or everything?
  • Mohsen Amini
    November 28, 2018 at 4:57 pm
    well, I’m just experiencing everything. so much stuff I need to know in c4d. here I used cache for all cloners. but ill do only for delay effectors also to see what happens. thanks, m8
