Activity Forums Maxon Cinema 4D Team Render – Some clients seem to be rendering different frame
  • Team Render – Some clients seem to be rendering different frame
    Posted by Jareb Coupe on February 28, 2016 at 7:28 pm
    I’ve seen this before, but never figured out what causes it. Adds to my perpetual list of Team Render issues.
    Specifically, it appears as though one of the clients in the swarm is rendering a different frame than the host. Here’s an image:
    It’s a 210 frame animation, but I’m just rendering a single still frame for testing – from within C4D, using the ‘Team Render to Picture Viewer’ option. Any ideas as to what causes this?
    Hobbyist level – R17
    Sebastian Rath replied 10 years, 5 months ago 3 Members · 2 Replies
  • Andy Sills
    February 29, 2016 at 6:28 pm
    I rarely use team render for a single frame dude.
    I’ve gotten the same issue with it so I just avoided it.
    Hopefully somebody has an answer here but I haven’t found anything as a fix. 🙁
  • Sebastian Rath
    March 6, 2016 at 3:38 pm
    Are you sure your clients use the same font? Install the fonts on your clients or convert the text object to a polygon object. Let me know if this fixed your problem.
    P.S. Keep in mind that the same font can also look slightly different between Operating Systems.
