Activity › Forums › Maxon Cinema 4D › Team Render Error “Could not open file…”
  • Team Render Error “Could not open file…”
    Posted by Ryan Paterson on May 27, 2015 at 7:44 pm
    So Team Render is all set up, my machine grabs the render job, creates the asset, downloads the asset, but then fails to open it. Never seen this before, and I’ve used this machine for Team Render many times before. Any ideas what could be going wrong?
    Ryan Paterson replied 11 years, 4 months ago 2 Members · 2 Replies
  • Ashly Sanford
    May 29, 2015 at 4:10 pm
    If the image is not absolute (in the tex folder with the file path removed in the material) that might be your problem. Sometimes team render doesn’t like pulling an image from a path.
  • Ryan Paterson
    June 2, 2015 at 6:08 pm
    Actually that made me realize what the problem was- the project file was on an external drive, as soon as I moved it to the system drive it worked just fine 🙂
    Thanks for the tip!
