Activity Forums Maxon Cinema 4D Team Render and Poser Object(Power Fusion)
  • Team Render and Poser Object(Power Fusion)
    Posted by Claude Johnson on January 3, 2014 at 3:03 am
    I have 2 computers rendering with Team Render. Both computer have R15 with the plug-in Poser Object. If the project is native C4D project, no problems. Both machines cooperate.If I add a Poser Object in the project (Local machine ) and start to Team Render , C4D on the client machine crashes and it gives me a crash report.
    iMac 24″, OSX 10.6.2, Vue 8 xStream, modo 401, C4D 11.5
    https://www.claude3D.com
    Brian Jones replied 12 years, 7 months ago 2 Members · 5 Replies
  • Claude Johnson
    January 4, 2014 at 12:43 pm
    I forgot to write my question. Is Poser Fusion supported in Team render? And a Happy New Year 🙂
    Mac Mini, OSX 10.9.1, Vue 8 xStream, modo 401, C4D 15
  • Claude Johnson
    January 6, 2014 at 4:03 am
    Update : After trying various combinations the C4D on the remote computer doesn’t crash any more. But it doesn’t render the Poser object. Only the C4D native objects. I’m sure my settings are OK as I tried to import Poser object with InterposerPro and it works fine. I send emails to Maxon and SmithMicro. Waiting for their answer.
  • Claude Johnson
    January 7, 2014 at 11:53 pm
    Got an answer from Maxon and Smith Micro
    1. Maxon : It should work
    2. Smith Micro : Not supported but may work if you do this and this. Poser should not be activated on the outside computer. Did everything.
    Still only the native C4D objects are rendered on the outside computer. Not the Poser objects. On the server (local) computer C4D and Poser objects are
    rendered.
    Team Render (R15) and Net Render (R11.5) give the same results (problem).
    I’m out of ideas. Anyone ?
  • Claude Johnson
    February 21, 2014 at 2:27 am
    Getting a bit of information from Smith Micro and the help of another user, we finally managed to have it work.
    https://www.claude3d.com/claude3d/Net_Render_for_C4D_with_Poser.html
    The main problem was with the Shared folder. Doesn’t seem to work. But using a Shared drive it did.
    Any comment is welcome 🙂
  • Brian Jones
    February 21, 2014 at 2:42 am
    thanks for the follow ups Claude
