  • Posted by Matthew Javier on January 26, 2009 at 7:39 pm
    Greetings!
    I needed some help with adding some TC windows. I have a 24 fps sequence and I need to have 24 and 30 fps TC burns. The TC reader will only read the QTs TC, but how do I add a 30 fps window? Thank you!
    -matt
    Michael Gossen replied 17 years, 7 months ago 2 Members · 3 Replies
  • Michael Gossen
    January 26, 2009 at 7:52 pm
    The ‘TC Generator’ filter in the ‘Effects > Video Filters > Video’ has setting for both DF and NDF. Will that work for you?
    Michael Gossen
    Helium Digital Media
  • Matthew Javier
    January 26, 2009 at 7:54 pm
    I need both TCs to slave to the 24 fps sequence timecode. If I do a generator, it will run independently from the sequence timecode. The TCs need to meet at the same minute, you know?
    -matt
  • Michael Gossen
    January 26, 2009 at 8:05 pm
    So export the 23.98 sequence to a QT at 23.98. Put that QT in a 29.97 sequence and use the TC Generator. Unfortunately, I don’t think you can nest sequences with different timebases, so you have to export.
    Michael Gossen
