Activity Forums Apple Final Cut Pro Legacy TC Window Burn Help
  • TC Window Burn Help
    Posted by Nelson May on September 2, 2009 at 1:43 am
    I am up against a wall and want to get this right. As I capture I am going to be looking this up. How do I do a TC window Burn? I am going to add to my file in the timeline. Then I want to do a QT export and burn it using idvd so I can watch with a client tomorrow morning.
    Do you add the burn to the file in FCP then export?
    G5, 1.7, 4MB RAM, 30″cine, G4, 1.6 2MB RAM, Mbox, Neumann TLM-103, FCP HD 5. Pro Tools, Adobe Creative Suite, Reason 3.0, Macromedia Studio, ProAnimator, HVX200 with Firestore v4.0
    Rafael Amador replied 16 years, 12 months ago 3 Members · 2 Replies
  • Bill Scheerer
    September 2, 2009 at 1:55 am
    Yes is the answer. Do it on the timeline then export. One of the effects reads the timeline timecode and the other one reads the source video timecode, I assume you want the source video timecode. Still new to FCP myself so the exact name of the effect I don’t remeber, I just played with it quickly, but it will do what you want.
  • Rafael Amador
    September 3, 2009 at 5:04 am
    There are two different filters that will burn the TC.
    One is the TC Reader. This will show the original TC of the footage that you put in the time line.
    With the TC Generator you can set the TC on display.
    To use this one you may need nest your sequence and drop it on top.
    Cheers,
    rafael
    http://www.nagavideo.com
