  • Posted by Mary Ann mcclure on September 21, 2007 at 6:09 pm
    Hello Helpful Ones,
    I am trying to output my FCP sequence to DVCam (not Mini DV). I thought I could bring down the TC from the sequence through the firewire onto tape? Am I mistaken? I am not getting the dialogue box either to input TC if I want to only black & code. It is a Sony DVcam w/ no model number on the front or back. It has no serial port for TC so I am just going firewire in. I need proper TC for duplication purposes. Client asked for Digi beta I was trying to save cost & thought DVcam would be OK for this purpose. It is just a sizzle reel & shouldn’t be broadcast. What no TC? It has a window and it is an editing deck…
    Mary Ann
    Mary Ann mcclure replied 19 years ago 2 Members · 6 Replies
  • Shane Ross
    September 21, 2007 at 6:10 pm
    Well, you can try this:
    TC to DSR-11
    Since FCP 4 we have been unable to stripe a new TC such as 00:58:00:00 or 01:58:00:00 to a DVCAM tape with the DSR-11. NO MORE!! I think I found a solution.
    Get SimpleVideoOut from the Apple (its free):
    https://developer.apple.com/samplecode/SimpleVideoOut/SimpleVideoOut.html
    Then create a QT Movie in FCP or Xpress Pro from a sequence which has the starting TC you want on the tape. I just tried it with 00:58:00:00. In the timeline, I just put Bars & Tone for 90 seconds and a black slug for 45 (to take me over 01:00:00:00). You could create a sequence with whatever combination you wanted with the TC set to start at whatever timecode you need for your choice. But the Timeline TC MUST be set to your desired starting code. The exported QT file will have this TC in it.
    Then load this DV QT movie into SimpleVideoOut (having selecting Firewire / Apple Firewire PAL or NTSC when you open the app).
    Now load a fresh DVCAM tape and set your DSR-11 to:
    REC MODE = DVCAM
    DV IN TC = EXTERNAL
    (Have the TC display turned on for this first test so you can verify it has worked.)
    Then just hold the REC and PLAY buttons together on the DSR-11 and press play in the SimpleVideoOut app and the new TC will be recorded to your DVCAM tape. Hey presto you are now able to stripe a tape with what ever timecode you want using a DSR-11.
    Remember to turn ‘DV IN TC’ back to INTERNAL on the DSR-11 when you come to record your edit to tape.
    The problem with the DSR-11 is that it is not the best deck and starting recording at the exact TC, but playing with the pre-rolls should eventually get it spot on. I have had some success with FCP’s ‘Edit to Tape’ and very good results with Avid Xpress Pro after a few tweaks.
    Also, if you just had a black QT file, you can change the starting TC to suite the tape; i.e. 00:58:00:00 or 02:58:00:00 etc without going back into FCP or Xpress Pro and rendering out another QT. To do this, just use Sebsky Tools to alter the starting TC of the file.
    https://www.dharmafilm.com/sebskytools/
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mary Ann mcclure
    September 21, 2007 at 6:39 pm
    Thanks Shane, that is quite a work around. I will give it a shot but what a huge pain in the…..
    Best
    M
  • Shane Ross
    September 21, 2007 at 6:47 pm
    It’s because the deck isn’t really designed to do this. You aren’t supposed to be able to do this. Really, for mastering you need a deck with RS-422 deck control. The DSR-11 (which I’ll wager this is, or the 25) is really meant as injest only…or mastering where you really don’t need TC to hit on hour 1. But mainly injest only.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mary Ann mcclure
    September 21, 2007 at 9:05 pm
    Is there any DVCam deck model that will receive TC or do I have to go back to Digi-Beta which is hard to find/rent now that I escaped LA & live in Santa Barbara.
  • Shane Ross
    September 21, 2007 at 9:06 pm
    The DSR-1500 does…
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Mary Ann mcclure
    September 21, 2007 at 9:09 pm
    Great to know for next time… thanks so much for the help.
    Best
    M
