Activity › Forums › Sony Cameras › TC from PMW-EX30 to HD1500
  • TC from PMW-EX30 to HD1500
    Posted by Brien Vorhees on September 16, 2011 at 5:24 pm
    Hopefully someone can help me out. I am trying to record from a EX-30 deck to a HD1500 using HD-SDI and I want to keep the original TC. I am setting the 1500 to use TC from the SDI input but it still is generating timecode from 0. Can someone clue me on what I might be doing wrong?
    Brien
    Ian Cook replied 15 years ago 2 Members · 1 Reply
  • Ian Cook
    September 16, 2011 at 6:30 pm
    On the 1500:
    TCG = SDI
    Preset/Regen = TC
    Run mode = Rec Run
    If you feed HDSDI from the EX30 to the HD1500 with these settings the 1500 will pick up the embedded TC on the SDI.
