Activity Forums Apple Final Cut Pro Legacy TC error in XML export w/speed change
  • TC error in XML export w/speed change
    Posted by Mathieu Marano on April 25, 2008 at 3:02 pm
    Hi, I’m trying to export an XML (and and an EDL) from a SD/10 bit UC sequence. The sequence contains 10 clips. 4 of them have regular speed change (not variable). I need to conform in a Smoke/Flame station which generally work very well with XML from FCP.
    The problem is that the timecode in and out points of the clips with speed change in the XML are all mixed up and wrong. If I try with an EDL,it does the same thing. Any clue or solutions from FCP gurus?
    Thanks a lot
    Mat
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
    Mathieu Marano replied 18 years, 4 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    April 25, 2008 at 10:22 pm
    Could you work around this by not doing the speed changes in FCP? Just insert all the media that it would take to perform it on the Flame?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Mathieu Marano
    April 28, 2008 at 5:00 pm
    Yes but I would be missing the point of doing an offline editing. If I have to redo the job in the Flame. This is a major problem that should be look after. I’m fighting with project managers who want to offline on AVID because of somewhat basic but important issues like that.
    I’m a diehard FCP user but I also know that Avid MC would do that without a glitch.
    Mathieu Marano
