Activity Forums Apple Final Cut Pro Legacy TC breaks when capturing ProRes HQ 1080i 29.97
  • TC breaks when capturing ProRes HQ 1080i 29.97
    Posted by Zepolveda on September 29, 2007 at 1:04 am
    I know FCP extremely well and do a fair amount of HD consulting. For whatever reason, I’ve been capturing off a Sony M-2000 HDCAM at 1080i 29.97 and FCP keeps either logging TC breaks or dropping frames when capturing even though there is no TC break on the tape(s). I am capturing at ProRes HQ 1080i 29.97 and important to note is that I have captured a DF 29.97 HDCAM at the same codec without breaks previously and can still output to the same deck without dropping.
    At this point I’m pretty frustrated…I was doing Capture Now and switched to batch, that didn’t help. I’ve gone through the deck menus, looked at my capture presets, checked my Kona 3 card format, switched the video playback from 10 to 8 bit…nada. And everything’s at drop frame.
    Can someone please help save me from the quagmires of Non-Controllable Device and the “Warn After Capture” clip setting? These captures are going to the graphics department and need to reference timecode, so the quick cheats in User Preferences won’t work for me.
    Could it be a 59.94 thing?
    thanks for your time!
    Machine: G5 PPC Quad, 4.5GB RAM, running 10.4.10 and FCP 6.0. Kona 3 with v.4.0 driver and a Sony M-2000 HDCAM. Capturing to eSATA array striped at RAID 0.
    Gary Adcock replied 18 years, 11 months ago 6 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    September 29, 2007 at 5:26 am
    I had similar problems capturing HDCAM at 23.98 with a Sony J3 player capturing via SDI. FCP was creating timecode breaks where there were none and an then of course it doesn’t have the ability to start capturing again after the timecode break because there weren’t any there in the first place. It turned a four hour session into a six hour session.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Sean Oneil
    September 29, 2007 at 6:47 am
    I’ve seen this a lot when the system can’t keep up. It seems to happen in lieu of getting a dropped frames warning.
  • David Roth weiss
    September 29, 2007 at 1:08 pm
    I’m capturing 23.98 HDCAM via a SDI through a Kona card as DVCProHD to four striped SATA drives with 200mbps write speed. I gon’t see how that is not able to keep up, and if it is having that problem why would it simply indicate dropped frames?
    David Roth Weiss
    Director/Editor
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
  • Gary Adcock
    September 29, 2007 at 1:13 pm
    [David Roth Weiss] “I’m capturing 23.98 HDCAM via a SDI through a Kona card as DVCProHD to four striped SATA drives with 200mbps write speed. I gon’t see how that is not able to keep up, and if it is having that problem why would it simply indicate dropped frames? “
    Check one of the files with the” show long frames” under the Tools Menu.
    FCP ( and AVID also) tend to drop a frame in the first 3-5 frames of a capture, Avids ignore this but FCP still warns people.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Sara Shier
    September 29, 2007 at 2:19 pm
    Hi…
    I’m not sure if this could be your problem, but it was mine.
    I have a MacPro Dual Quad Core with 5 GB of RAM, FCP 6 and an AJA Kona 3 card (software v 4.0) capturing to internal SATA 7200 drives. I was trying to capture Apple Prores 422 HQ (1080i 29.97) from an HDW-D1800 HDCAM deck. I couldn’t capture that format or reqular quality Apple Prores because of dropped frames. If I told FCP to ignore dropped frames, I could capture but not playback. DVCProHD worked fine. My system’s definitely beefy enough to handle ProRes. I tried everything I could think of and the following morning I called AJA for ideas. They told me that there’s a software bug with the Kona 3/driver v 4.0 – supposedly systems with over 2GB of RAM have problems working with Prores because of this dropped-frame issue. So I removed 3GBs of RAM and bingo! They’re apparently working on a fix.
    So I’m not sure if this might be related to your problem but you might look into it. I posted this awhile back in the Kona forum and a couple of people said that their systems were over 2GB and they weren’t having problems. This is what AJA told me and it fixed my problem (although 2GB wasn’t enough for the work I was doing with prores HQ in FCP so I had to go back up to 5GB after capture for editing)
    Good luck!
  • David Roth weiss
    September 29, 2007 at 6:23 pm
    Hi Gary,
    Well, the good news is that the only long frames were at the very start (first frame) of each clip captured. So, if I’m understanding things correctly that doesn’t seem to indicate a problem.
    The bad news is that all files were captured manually and that FCP was indeed stopping capture where no timecode breaks existed (in the middle of interviews) but without stopping the deck. This forced me to manually find and set an overlapping in point in the middle of an interview at which to begin a new capture–a highly undesireable way to work. BTW, the places at which capture stopped were not repeatable.
    Any other ideas what could be causing this???
    Thanks for your help,
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • David Roth weiss
    September 29, 2007 at 6:28 pm
    [SaraAnn] “I called AJA for ideas. They told me that there’s a software bug with the Kona 3/driver v 4.0 – supposedly systems with over 2GB of RAM have problems working with Prores because of this dropped-frame issue. So I removed 3GBs of RAM and bingo! They’re apparently working on a fix.”
    I read that SaraAnn and I certainly hope that’s not a problem with capturing DVCProHD now. I’ll check with Kona Monday to see what they say. And, I’m using a G5 not a MacPro, which I’ve not heard anything about in this regard.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Zepolveda
    September 30, 2007 at 2:28 am
    After a lot of hand-wringing, I think the TC break thing (in ProRes, anyway) is due to a 10-bit digitizer conflict with the Kona card. Thanks for all your responses, by the way.
    I messed around with the capture preset and changed the Digitizer field in ProResHQ to Kona 8-bit, and that seemed to work at 1080i 29.97 (the Digitizer field was defaulted to 10bit at both ProRes and ProResHQ.)
    and for David, I would check on your J-H3 to see if it is mistakenly on the pull-down setting? It will read 23.98PD if it is, but for DVCProHD it should be 23.98psf.
  • David Roth weiss
    September 30, 2007 at 2:36 am
    [zepolveda] “and for David, I would check on your J-H3 to see if it is mistakenly on the pull-down setting? It will read 23.98PD if it is, but for DVCProHD it should be 23.98psf.”
    Nope, it was definitely set on 23.98psf. The files are all perfect at 23.98p.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Patrick Troy
    October 1, 2007 at 1:15 am
    I had the same issue caturing ProRes throught the Kona 3
    Hanging up intermittently through capture, no amount of tweaking would solve it.
    After about 50 hrs of capture headache I finally found a sniff of a solution
    I emailed AJA and they sent me a little script to go into FCP plugin folder called “DisableAltETTPolling.txt” tht solved it for me.
    regards
    Patrick
