Activity › Forums › Apple Final Cut Pro Legacy › TC Breaks during HDCAM Capture
  • TC Breaks during HDCAM Capture
    Posted by D-bres on November 14, 2007 at 5:25 pm
    I am trying to load in some HD material from HDCAM 1080 23.98. My capture preset is AJA Kona3: 1080psf 23.98 10 bit and my device control is AJA Kona3: 23.98 Sony VTR B. I am using the Sony HDCAM HDW-1800. If I try to batch capture or just capture now the capture will stop because of timecode breaks and then scroll back very slowly looking for the break and create a new clip. I have about 30 minutes of footage and I need to figure this out.
    Danny
    Gary Morris mcbeath replied 18 years, 10 months ago 4 Members · 3 Replies
  • Chris Borjis
    November 14, 2007 at 5:32 pm
    I’ve heard of this before and I think its a setting in the deck that fixes this. Sorry I can’t recall what it was.
  • David Roth weiss
    November 14, 2007 at 6:07 pm
    I experienced the same thing with my Kona LH using the Sony J3 HDCAM player, only there were no actual timecode breaks upon closer scrutiny. Making matters worse, because there was no actual break in the timecode the deck was unable to seek a new in point, so I had to search thje captured clip myself and manually set the new inpoint every time. Never found a solution. BTW, I was capturing via SDI…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY™
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Gary Morris mcbeath
    November 15, 2007 at 2:36 am
    When the HDCAM tape doesn’t have a few of timecode on each end of the clip to be captured (“handles”), in which to spool-up or down, it will demonstrate the problem discussed here. A break in the TC, or a blank spot on the tape will do this.
    My solution has been to enter the clip name, cue-up to a spot a few seconds before the clip start, hit play, and use “Capture Now” to capture the clip or footage you want. You will have to type in any logging information you want after you’ve captured the clip.
    Pain in the rear, but it works when the shooter didn’t keep good continous time code by using the return button after reviewing a shot, or shutting off and then repowering the camera. Also, shooter should always pre-roll and post-roll about 10 seconds; especially important at the beginning or end of the tape.
    Gary
    SaltAire Cinema Productions
