Activity Forums Avid Media Composer TC and Avid
  • Geraint Pari huws
    November 1, 2006 at 3:52 pm
    symphony/nitris (maybe addrenaline) has an ext ltc input, and you can switch in the capture window to ext ltc when loading.
  • Joe Biscotti
    November 1, 2006 at 3:58 pm
    what about xpress pro HD???
  • Dave Schweitzer
    November 3, 2006 at 5:05 am
    Yes. Current versions of MC and AXP have that ability. I forgot when this feature started, it’s been there a couple years at least.
    What you do is select the master clipand go to Special>Read Audio Timecode.
    Here you can select Ch.1 for the TC and assign it to an Auxiliary TC track.
    Group your clips based on this auxiliary TC and start your multicam edit.
  • Michael Phillips
    November 3, 2006 at 5:38 pm
    Read Audio Timecode has been a feature since 1996… it dissapeared for a while due to some compile errors, but it is back in both Media Composer and Xpress Pro.
    anything 24fps
  • Tucklis
    November 8, 2006 at 10:43 pm
    TC is usually carried through your REMOTE CABLE. So as long as you have your TC button highlighted in the capture tool, it shouldn’t be a problem….otherwise you might as well be capturing wild…..Don’t forget OMF exports or AIF (depending on whay output yu need).
