Activity Forums Apple Final Cut Pro Legacy Tascam FW-1082 setup question
  • Tascam FW-1082 setup question
    Posted by Ric Shellhammer on January 5, 2007 at 1:17 am
    Hello,
    We’re trying to integrate the 1082 into a Final Cut Pro edit system. We have a betasp deck going in to ch1 & ch2, a vhs deck into ch3 & ch4, and a dvd deck into ch5 & ch6. Main mixer outs feed into a Kona LHe digitizer board while the stereo headphone outs feed monitors (real funky). I can successfully monitor the computer and analog signals and record from the betasp source into FCP.
    The problem is a Sony 1500 DVcam deck thats setup to digitize through firewire. When I enter the log & capture in FCP both the video and audio are there but no audio through the 1082. The deck is connected on the same firewire buss as the 1082 although when I spoke with Tascam customer service he said that shouldn’t be an issue. He also had to solution. This has to be easy…right? Any suggestion as to how to monitor in that situation?
    thanks,
    Ric Shellhammer
    Pegasus Productions
    Oceanside, California
    http://www.pegasusproductions.tv
    760-435-9864
    Ric Shellhammer replied 19 years, 7 months ago 2 Members · 2 Replies
  • Travis Ballstadt
    January 5, 2007 at 3:43 am
    Tech support is right. It shouldn’t be an issue, as I have mine in between my G5 and a DVCPro deck with no issues.
    Wait, I just reread your post. Your DV audio is getting into the computer, but you just can’t hear it through the 1082? Run your analog outputs from the DV deck into 7&8 of the mixer.
    travis ballstadt
    http://www.thrillcateditorial.com
  • Ric Shellhammer
    January 5, 2007 at 4:01 pm
    Got the solution from another site. I didn’t have preview checked in Audio section of the clip settings tab.
    thanks,
    ric
