Activity Forums Adobe Premiere Pro Targeting Audio tracks CS3
  • Targeting Audio tracks CS3
    Posted by David Erwin on September 12, 2008 at 8:33 pm
    I working in DVCPRO50 – so I have four channels of audio –
    1. how do you set it up where you target which tracks to use, instead of having to take all four. I want channel one and two only.
    2. when editing, if i extract, only channel one extracts leaving the other audio behind. How do you select more than one audio track for editing.
    Vince Becquiot replied 18 years ago 3 Members · 4 Replies
  • Vince Becquiot
    September 13, 2008 at 12:29 am
    Before you bring the P2 clips to the timeline, select them all, then go to Clip > Audio options > Source channel mappings.
    From there you can uncheck unused channels and assign the others to either a stereo track or 2 mono tracks.
    Cheers,
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    Santa Rosa, CA
  • David Erwin
    September 15, 2008 at 12:04 am
    Thanks again, I read the manual on channel mapping but did not pick up on that. You saved me hours of keystrokes.
    Do you know if there is a way to select multiple audio tracks for trimming?
    de
  • Jon Barrie
    September 15, 2008 at 12:11 am
    Hi david,
    don’t select tracks, select the clips themselves and just use the trim tools (ripple) and all selected bits will follow suit.
    – Jon Barrie 😉
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Vince Becquiot
    September 15, 2008 at 12:25 am
    Glad it worked out. Just saw Jon’s got your answer.
    BTW, to select several audio tracks, hold Ctrl+Alt and click on the audio tracks.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    Santa Rosa, CA
