Activity Forums Adobe After Effects Targeting a Light at a 3D layer
  • Targeting a Light at a 3D layer
    Posted by Eric Chard on June 13, 2013 at 5:13 am
    I wanted to target a light at a layer, so I used the pickwhip to substitute the layer’s position for the lights POI.
    This worked fine.
    However, I wanted greater control, and the ability to fine-tune and otherwise animate the lite’s target, so I did something that would work perfectly in my 3D app, but doesn’t in AE:
    I created a Null, and parented it to the moving layer.
    I pickwhipped the Null’s position the same way I did before, for the lights POI position.
    Sadly, this did not work. In 3D terms I need the ‘world coordinates’ of the null, not the keyframed coords, since they just sit at 0/0/0.
    How can one get the light to follow the NULL, with the null parented to the moving layer?
    Suggestions?
    Thanks.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Eric Chard replied 13 years, 2 months ago 2 Members · 2 Replies
  • John Cuevas
    June 13, 2013 at 5:13 pm
    Eric, post your question in the Expressions Forum, I know there is a way to do this, but I just can’t seem to work it out, where Dan or Kevin will probably be able to work this out immediately.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Eric Chard
    June 13, 2013 at 5:24 pm
    Will do, thanks for the suggestion!
