Activity Forums Maxon Cinema 4D Target Camera Question
  • Target Camera Question
    Posted by Noizzz on January 25, 2008 at 12:00 pm
    Hello,
    when I use target camera, and animate its position, it also rotates the camera itself in the unlocked axis. This is especialy a problem when I move exactly over the target object (when looking from top view). I understand why this happens, but is there a way change this? So that the topside of my view is always facing North (the Z axis)? I hope you understand my question, if not I can post an example of one of my renders.
    Greetings
    NoiZ
    Noizzz replied 18 years, 8 months ago 3 Members · 3 Replies
  • Jason Ripple
    January 25, 2008 at 3:45 pm
    I know exactly what you are talking about, the camera spins as you move over the object.
    Not sure how to fix the target camera…..but
    One method, is just to use a reg. camera and as you animate it make sure it is pointed in the right direction. Obviously, this method would take more time to tweak.
    Just a thought…:)
    Once you go Mac, you’ll never go back!
  • Adam Trachtenberg
    January 25, 2008 at 11:43 pm
    If you look in the target tag’s properties you’ll see a spot for “up vector”. Place a null above your object in 3D space and assign it to the target tag as it’s up vector.
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Noizzz
    January 28, 2008 at 5:20 pm
    …the simplicity… thanx!
