Activity Forums Apple Final Cut Pro Legacy Targa – importing as 0 frame leangth?
  • Targa – importing as 0 frame leangth?
    Posted by Chilled on August 3, 2005 at 8:03 am
    Targa files importing with end time 1 frame before start time??
    Have set still duration to 1 frame in settings but because of the end time being before start time each clip imports with a leangth of 0 frames, and hence gives ‘insufficient content for edit’ error message.
    When clip duration is manually changed to 1 frame they drop onto timeline fine – but obviously we dont want to have to change 300+ frames per targa seq.
    Dual 2Ghz, 10.3.9, FCP 5.0.2,
    Chilled replied 21 years, 1 month ago 1 Member · 1 Reply
  • Chilled
    August 3, 2005 at 9:52 am
    Have found a work around!!!
    Set still duration to 2 frames in user settings – Stills then import as 1 frame long – hopefully Apple will fix this soon.
    Robin
