Activity › Forums › Panasonic Cameras › Tapes for HDX900
Tapes for HDX900
Posted by Pat Mcgowan on August 4, 2006 at 3:44 pmAnyone know if the HDX 900 will take a standard DVCPRO 66 tape?
Richard Boghosian replied 20 years, 1 month ago 5 Members · 10 Replies -
John Sharaf
August 4, 2006 at 5:07 pmPat,
This is one of my major gripes with the HVX; it takes the same size tape as the SDX, namely the “medium” size whereas the Varicam takes the “large” size. Everyone must beware that on shoots where these two cameras will be comingled that two different sized tapes will be required.
JS
Pat Mcgowan
August 4, 2006 at 8:36 pmA bit of a hassle when both cameras are used for sure. So, the answer to my question is yes, a standard DVCPRO66 tape can be used in the HVX900? As opposed to a particular tape stock for HD.
Tony
August 5, 2006 at 6:03 pmPat,
Read the specific spec online at the Panasonic website.
Download the HDX-900 brochure where you find the info.
Tony Salgado
Pat Mcgowan
August 7, 2006 at 1:38 pmSo only questions that aren’t addressed in manufacturer literature and websites can be answered here Tony?
Richard Boghosian
August 9, 2006 at 1:30 amI am using only the red cap tape product with success in the Varicam and then in the 1200A. Using the yellow cap tape (Fuji) and then inserting a red cap tape (also Fuji) into the 1200a makes the head clog. Anyone else having this issue in post? So I’m hunting down a supply of red cap M cassettes for the HDX900 I have on order.
Richard Boghosian
Bogh AV Productions -
John Sharaf
August 9, 2006 at 1:35 amRichard,
Red and Yellow only refers to the color of the plastic case; the tape inside is the same!
JS
Richard Boghosian
August 9, 2006 at 8:00 pmThat’s what I believe, but practice has proven differently-at least in my 1200a Deck
Richard Boghosian
Leo Ticheli
August 9, 2006 at 8:47 pmI’m willing to place a small wager that the different tapes have nothing whatsoever to do with your machine problem.
It’s not unusual to make erroneous diagnoses when one thing, by sheer chance alone, seems to produce a given result.
Unless something has changed, the manufacturer of the tapes says that they are absolutely identical except for the case color and text. If this is no longer the case, it’s important news for all of us.
I suggest you have the problem checked out before it causes more trouble, probably when you need the machine most!
Also, unless you are getting some marketing/markup benefit from using the more expensive tapes, you are not doing yourself a favor using them.
Hope you get it sorted out!
Good shooting!
Leo
Pat Mcgowan
August 23, 2006 at 1:52 amCan we use “yellow cap” FUJI 66 DVCPRO tapes in the HVX900 camera?
Richard Boghosian
August 25, 2006 at 6:26 pmSwitched to the yellow cap Panasonic product, and no problem. Alex at Panasonic service suggests (of course) that I be using Panasonic tapes. If that’s what it takes, then so be it. And now, FYI, Panasonic charges the same price for Red cap as Yellow cap. Fuji still gets a premium for the red cap, for now.
Still waiting for the 900 camera. But I have tape.
Richard Boghosian
Bogh AV Productions
