Activity › Forums › Adobe Illustrator › Tapered ZigZag
  • Tapered ZigZag
    Posted by Matthew Beall on January 31, 2017 at 7:44 pm
    I have a spline with a zigzag distortion on it, but I want the effect tapered so it starts as a straight line and then gradually zigzags. How do I do that?
    Matthew Beall replied 9 years, 7 months ago 2 Members · 2 Replies
  • Vincent Rosati
    February 24, 2017 at 12:59 am
    I realize you may have resolved this already, but I’m just seeing it now.
    11068_effectandenvelopetopobjectdistort.ai.zip
    The included steps are:
    1 – Start with a standard, straight, 2-point path.
    2 – Apply Effect > Distort > Zig Zag.
    3 – Create a “Top Object” in the shape of a triangle, that is the desired shape of your taper. Again, a basic shape, 3-points, no curves.
    4 – Make sure this top object is layered above the zig zag, then select both the zig zag and the top object and Object > Envelope Distort > Make with Top Object.
    Then add an additional path to the tip as needed.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
  • Matthew Beall
    February 24, 2017 at 3:24 pm
    Thank you Vince!
    I had NOT figured that out yet, in fact I had made the necessary splines in 3DSMax as a quick fix..!
    This helps a lot, thank you
