Activity › Forums › Adobe After Effects › Taper stroke effect for Shape layers?
Posted by Bart Stevens on December 19, 2007 at 12:54 amI’ve been recently playing around with Shape Layers in CS3, an was wondering if there is any way to get a taper effect for the stroke?
I can get satifactory results with Trapcode 3d stroke, and Trapcode Particular, but it would be great to use the shape layers instead.
I know the “rounded end” is somewhat similar, but I have no idea what type of file AE looks at to create this. I was just wondering if anyone had any ideas about this.
-BRoei Tzoref replied 9 years, 6 months ago 11 Members · 11 Replies -
Trent Armstrong
December 19, 2007 at 5:46 pmI’m not too sure exactly what you are looking for but a very simple way to get a sort of tapered look on a stroke around a shape is to use the shape tool as a mask on a solid instead of creating a shape layer. Then apply VEGAS to the layer. It will look at the mask and give you tapered segments.
Set the segments to 1
Length to about 0.28
Width around 7
Hardness to about 0.5Then use a negative rotation to get the stroke to move along the mask path in what appears to be positive direction with the tail trailing behind.
Let me know if that doesn’t give you what you are looking for.
Trent
Trent Armstrong – Creative Cow Leader
https://www.dallasaeug.com -
Jenia Ukraine
October 10, 2013 at 2:31 pmI get what he means, and now in 2013 I’m wandering about that too.
My question is simple, is it posible to make by using other plugins or by some shape functions the taper effect? which already is in plugin 3D stroke (named – ‘taper’)
The reason why I’m wandering, cuz 3d stroke in precomp with ‘collapse transformations’ dosen’t move in Z access, and doesn’t rotating in Z. Which my main problem is.
Scott Green
October 23, 2014 at 1:20 pm7 years on from the original post and still no easy solution to make a tapered stroke line, very disappointing.
Music Videos, Motion Graphics, Creative Multimedia, Video Production, VFX and Graphic Design by Splurj Creative Multimedia
Michael Szalapski
September 10, 2015 at 1:53 pmAdobe doesn’t track feature requests in forum posts. There could be a hundred of us here saying we want something, but it wouldn’t do as much good as an official request.
If you would like to see this feature introduced to AE, please file a feature request! https://www.adobe.com/products/wishform.html
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Christopher Dinardo
June 15, 2016 at 9:32 pmThere is a way to do it that is a bit of a hack:
Create a keyframe for your shape layer path.
Cut that keyframe
Open Illustrator and paste it into a new document
Apply a stroke color and adjust the stroke’s tapering to your liking
Expand the appearance of the stroke
Copy that object from illustrator
Create a new Solid above your original Shape layer in AE
Paste the Illustrator object onto your Solid
Use that Solid layer (That now has your Illustrator Object as a mask channel) as a Track Matte
Kalleheikki Kannisto
June 16, 2016 at 7:57 amYou can create a tapered mask path stroke with Video Copilot’s free Saber plug-in. Aside from many way more interesting things.
Christopher Dinardo
June 16, 2016 at 2:05 pmOH! I haven’t played with that one yet since it seemed to be all about the lightsabers.
Joe Clay
June 17, 2016 at 5:22 amGreat idea Kalle! I love alternate uses for plugins!
Joe Clay
Workbench.tv -
Jacob Peñaloza
September 21, 2016 at 9:14 pmA shape layer line with a feather mask, that works for me, masks in shape layers is really helpfull
