Activity Forums Apple Final Cut Pro Legacy Tapeless workflow and rendering
  • Tapeless workflow and rendering
    Posted by Kim Rowley on November 3, 2010 at 11:44 am
    Is their any harm in outputting via file an unrendered sequence? Let’s say I made a change to a previously rendered sequence and thus the whole long file becomes unrendered (orange line in timeline not red). Is is OK to output the sequence (ProRes HQ) without re-rendering the entire sequence again? I have done it and I see no difference but just want to through it out to “pasture” to see if I’m being foolish. It seems to save a lot of time not having to render and then output. (Obviously I am talking about minor changes that I don’t necessarily have to verify in real time.)
    Dual 3 GHz Dual Core Intel, 4GB RAM, ATI Radeon X1900, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.0.6), OS X10.4.11
    Kim Rowley replied 15 years, 9 months ago 3 Members · 3 Replies
  • Ben Holmes
    November 3, 2010 at 12:39 pm
    FCP needs to render the sequence when you output it – so if you are outputting the sequence in the same codec you are rendering in, you would see little timesaving via either method.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
  • Gary Askham
    November 3, 2010 at 2:04 pm
    FCP renders as it exports… however only the exported file benefits – the sequence itself stays as it was.
    So I recommend rendering first and then exporting. If the computer is going to go to the trouble of rendering you may as well retain all it’s hard work.
    FCP and Avid Technical Support
    Air Post Production
    Shoreditch – London
  • Kim Rowley
    November 5, 2010 at 6:26 pm
    Thanks for the replies guys. Cheers
