Activity › Forums › Blackmagic Design › tapeless workflow
tapeless workflow
Posted by Randy Johnson on February 6, 2009 at 4:02 pmIf I go tapeless is there a file converter program that will convert natvie HDV to a file I can use with my Intensity pro?
Randy Johnson replied 17 years, 7 months ago 2 Members · 3 Replies -
Danny Hays
February 12, 2009 at 5:08 pmIf you capture tapeless with an Intensity Pro, why dont you record component in as Pro rez 422 or uncompressed 4.2.2 color space and bypass the HDV compression completley? I’ve been researching getting an Intensity Pro for just that reason. Bypassing the tape and the firewire you can record straight from the camera sensor chip to your hard drive. Hope this helps. If you do a comparison between HDV and this method I would love to see the resluts as I cant find anyone doing it yet. Danny Hays
Danny Hays
February 12, 2009 at 5:11 pmWhy not capture component live from the camera without tape or firewire? You can bypass the HDV compression alltogether that way. Danny Hays
Randy Johnson
February 12, 2009 at 6:29 pmI guess what im saying if I get a onboard HD like a FS-5 it will capture in native HDV. Can I just copy those files to my HD then import them into Premiere? Or do I need to convert them to something I can edit with the Intensity pro?
Randy Johnson
Rando1968@comcast.net
