Activity › Forums › AJA Video Systems › “Tape Trouble. Check VTR.” Error Message….
J. Tad newberry replied 17 years ago 22 Members · 33 Replies
Tom Matthies
April 20, 2007 at 7:59 pm -
Guillem Ventura
April 24, 2007 at 2:50 pmSame problem here!
My setup: Quad-Xeon Macpro, OSX 10.4.8, Kona 3, SRW-1 HDCam VTR…
Did you upgrade to 10.4.9? would it solve the issue? What OS are you using?
I just emailed AJA support but if you were so kind please send me the file they sent you to:Thanks!
da Postpo-dude!
Quimera Producciones, Madrid. -
Todd Stock
April 24, 2007 at 3:58 pmThe patch didn’t work for me, still about 5 errors per hour.
Please contact AJA directly if you want to try the patch here’s the contact:
Jim Schroeder
AJA Video Technical SupportEmail: jims@aja.com
Phone: 530-271-3177If you don’t need timecode or deck control, you can get a solid capture by selecting NON-CONTROLLABLE DEVICE.
-Todd
Chris Acker
May 24, 2007 at 1:55 pmI, too was having this same issue with DigiBeta deck, FCP and AJA Kona 2 card. Never happened before (even on long captures). After trying 3 different decks to no avail, then reading this post and realizing the issue seemed to be with RS422, I simply changed cat 5 patch cable (I run from my suite to an equipment room, where control can be switched to different machines through a patch panel).
Anyway, that did the trick. So, be sure to have “clean” RS422 paths.
Chris
Casey Baugess
June 4, 2007 at 8:31 pmHello all, I’m experiencing the same problem with capture in FCP! Anyone still have that patch? Or any other solutions to stop the above problem with the AJA card? Please help! Thanks.
Casey Baugess
June 4, 2007 at 8:53 pmThanks! I got it from AJA Direct. Thank you for the response. I thought this might be faster than AJA.
Gnu Gnushka
June 5, 2007 at 3:35 am -
Cmpnsm
June 6, 2007 at 2:08 am
