Activity Forums Avid Media Composer Tape Rewind Visual Effect
  • Tape Rewind Visual Effect
    Posted by Caton Clark on February 23, 2009 at 5:42 pm
    Hello,
    I’m trying to recreate the look of a tape rewinding in a sequence. I’ve got the fast motion reverse footage, but i’d like to add some distortion like an old school VHS.
    Any ideas on how to create this?
    Ra-ey Saleh replied 17 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Michael Hancock
    February 23, 2009 at 5:45 pm
    Easiest way? Lay your original bit to tape (playing forward), then open your capture tool, turn off deck control and timecode, hit record, then hit Rewind on your tape deck. It should have all the rewind goodness you like and you won’t have to create anything. Just timeramp and adjust the speed more in your edit system to fit your cuts and you’re done.
    Michael
  • Caton Clark
    February 23, 2009 at 6:51 pm
    If don’t have access to the tape right now or the deck, are there any other tricks?
  • Ra-ey Saleh
    February 24, 2009 at 1:05 am
    There are a couple of ways.
    Do you have access to Sapphire v2?
  • Caton Clark
    February 24, 2009 at 4:10 pm
    no, they have BCC 3 here.
  • Ra-ey Saleh
    February 25, 2009 at 3:53 am
    Not sure what’s in that version, but to be honest, I’d download the 3week free trail version on Sapphire v3, which has a TVDamage effect in it.
    Reverse your footage with a Timewarp, and apply the effect. It will have more parameters then you need, but you should be able to get a really good effect, and it’s free.
  • Caton Clark
    February 26, 2009 at 7:06 pm
    I was able to find an equivalent TV Damage effect in Boris!
    thanks for the tip!
  • Ra-ey Saleh
    February 26, 2009 at 10:39 pm
    No worries, wasn’t sure if BCC3 had it.
  • Nathan Mulready
    March 15, 2009 at 10:32 pm
    what was the BCC effect called? – i have a similar problem at the moment
    If I have seen further it is by standing on the shoulders of Giants.
  • Ra-ey Saleh
    March 15, 2009 at 10:49 pm
    I’m running BCC5 and in there it’s in the OpenGL tab, called BCC Damaged TV.
