  • Posted by Pol on September 28, 2005 at 8:38 pm
    When I capture a whole tape, the reel number after each timecode break chances. For example: if I name the tape ‘digi1’ and the capture abort on a timecode break, the tape name chances to ‘digi1-B’. But it’s still the same tape, so the tape name should still be ‘digi1’.
    I understand that the name of the clip would chance, but the tape reel should be the same.
    Am I missing something?
    Pol replied 20 years, 11 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    September 28, 2005 at 9:12 pm
    Its because each TC break is “considered” a different reel.
    At the pro level accurate TC is extremely important.
    TC on a single reel should be continuous, by design.
    If a “break” is detected, the software identifies the next “TC area” as a different “sub-reel”.
    That way if there are several identical TC numbers (many times the camcorder resets to 00:00:00 if there’s a break),
    if the reel name has a -B or -C after the name, you’ll know better where on the reel to LOOK for the logged cut.
    A good way to avoid this is to NOT capture an entire tape, but manually mark your good takes “by hand” and then capture them as you mark them.
    Another method, which will be even BETTER if you need to “BATCH” digitize clips now or at a later date, is to connect two DV decks or camcorders together via FireWire and make a new copy of the tape(s) with broken TC.
    The copy will have no generation loss (it will look exactly like the original) and have a new continuous TC.
    You would then only capture from the copy and avoid using the original tape with the faulty TC.
  • Pol
    September 28, 2005 at 10:00 pm
    Yes, I understand why FCP does that. I’v been working on Avid for years and Avid doesn’t chance the reel name after a timecode break. I just want to know if FCP can do the same thing, keeping the reel name after a timecode break.
