Activity › Forums › Apple Final Cut Pro Legacy › tape problem prevents capture & transfers to copy?
  • tape problem prevents capture & transfers to copy?
    Posted by Peter Ralph on November 16, 2006 at 2:14 pm
    I received a tape from a client – home movie type stuff recorded with a sony DV handycam – don’t know the model. Before capturing the tape I duplicated it and captured the copy. FCP would not capture because of an error, first it reported time code break – then an error for which I could not get details. I narrowed the problem down to a specific point on the tape. Could not capture that section. I made another copy – same problem in the same place. I went back to the original tape – again same problem in the same place.
    what type of problem might a tape have that would prevent capture even when copied? The original tape seems to hand momentarily at the critical point – but there is no timecode break there?
    Peter Ralph replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
