Activity › Forums › Avid Media Composer › Tape Name| Reel Name | Red Cine X Pro
  • Tape Name| Reel Name | Red Cine X Pro
    Posted by Vipin Vishwakarma on February 14, 2020 at 7:24 am
    Hi Guys,
    While Transcoding(in RED Cine X Pro) RED Camera Footage, .R3D Files which has REEL ID(Tape Name) is coming properly while transcoding to Avid(DNxHD) Files.
    But REEL NAME, TAPE NAME is not coming in the .MOV Transcodes.
    Help Needed.
    Vipin
    Michael Phillips replied 6 years, 6 months ago 3 Members · 6 Replies
  • Glenn Sakatch
    February 14, 2020 at 5:16 pm
    Sorry…trying to figure out your screen shot… are you asking people in the Avid Forum why Premiere isn’t liking your red cine x transcodes?
    Just because you made DNXHD clips, doesn’t make it an Avid issue, if i’m reading this correctly.
    Glenn
  • Michael Phillips
    February 14, 2020 at 7:47 pm
    MXF contains the TAPE name as metadata in the MXF wrapper and does not use the filename you see at the desktop level. Conversely, Media Composer does not support embedded REEL in a MOV file and will only use the filename. That value is tracked in the Source File column.
    Michael
  • Vipin Vishwakarma
    February 18, 2020 at 6:13 pm
    Hi Michael,
    But if I transcode in Resolve it’s coming coming Source name File Name.
    Is there any option in Red Cine X as like resolve?
    Vipin
  • Michael Phillips
    February 18, 2020 at 7:03 pm
    If you create MXF OPAtom (not OP1a), and you ensure that REEL is set to filename in Resolve settings, the resulting MXF file will have the filename in the “Tape” column.
    Michael
  • Vipin Vishwakarma
    February 19, 2020 at 3:40 am
    Hi Michael,
    Is this possible in RED Cine X transcoding to .mov?
    Vipin
  • Michael Phillips
    February 23, 2020 at 3:49 am
    If it did, it wouldn’t matter with Media Composer as it does not support embedded REEL in MOV files.
    Michael
