Activity Forums Apple Final Cut Pro Legacy Tape Name change when doing XDCAM Ingesting
  • Tape Name change when doing XDCAM Ingesting
    Posted by Michael Cavanagh on September 14, 2009 at 8:16 pm
    Hello,
    We have just installed a new Mac running Snow Leopard with Final Cut 7. we are about to import a project from a PDW-1500 XDCAM deck via I.link . We will be doing some collaborative editing and need to use EDLs the problem we are having is that we are are unable to rename the tapes. as far as we know non of the tapes have been named during the shoot so they are coming up as unnamed. our attempts to rename the tape via final cut have failed. we keep getting the error message something like:
    Unable to rename try using fewer characters or remove punctuation (sorry translated badly from swedish)
    even when only using one character
    We have read write access to the tape and can import clips. We can rename the source tittle however when viewing the EDL file it specifies source tape as: unnamed
    any idea as to how to get around this one… thanks
    Michael
    Jason Tobias replied 15 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Mark Raudonis
    September 14, 2009 at 10:18 pm
    Renaming of XDCAM discs will happen via the Sony Log & Transfer tool, NOT FCP. Read up on the instructions that come with that piece of software.
    Mark
  • Jeremy Garchow
    September 15, 2009 at 12:16 am
    I don’t think the Sony software is Snow Leopard approved?
  • Michael Cavanagh
    September 15, 2009 at 9:07 am
    Hi thanks for your feedback.. I have some more information about this problem. we are using XDCAM Transfer 2.10 and i have attempted to rename the tape when it comes up on the desktop by going to info. When i try to rename within Transfer under the information tab the Untitled is grayed out. even though the tape is not write protected. i moved the deeck to another comptuer running lepord 10.5.5 which has a copy of XDCAM Transfer 1.1 installed here i attempted to rename the tape using File – Rename this time it says failed to rename tape.
    so to recap i have attempted the following:
    using snow leopard and XDCAM Transfer 2.10
    tried renaming on the desktop and within the transfer program
    Using Leopard and XDCAM Transfer 1.1
    Attempted to rename using file – rename
    The Disk is not coming up in finder
    both attempts have failed
    any other suggestions? †
  • Daniel Wright
    September 16, 2009 at 8:16 pm
    I think your issue may be related to the FAM driver, which is part of the XDCAM Transfer package.
    I have no information as to whether the FAM driver works on Snow Leopard or not. I haven’t seen any posts saying it doesn’t, so it may be OK. However, as previously mentioned, the word from Sony is that Snow Leopard is not supported yet, so I would stick with Leopard unless you have a compelling reason not to.
    XDCAM Transfer version 1.1 is really old, probably from before the time of the Leopard OS. I Suggest you update XDCAM Transfer on Leopard to ver 2.10 so that you have the latest FAM driver. There is no reason to stick with such an old version when you can download a later one for free.
    You should then be able to rename your discs by your preferred method (Finder or via XDCAM Transfer).
    By the way, you have checked that your deck is set to the same recording format as the clips on your discs, haven’t you? If there is a mismatch, the rec-inhibit light will be on and the deck won’t let you write anything at all, not even just to rename the disc.
  • Michael Cavanagh
    September 16, 2009 at 8:51 pm
    Hello,
    thanks for all you comments, we solved this problem by updating the Firmware on our Sony PDW-1500 from v1.45 to v1.60. we got the hint that it may be the deck becuase we where able to rename on both TDK and Sony type disks but not the Fujifilm. Im not 100% sure it was the firmware setting or just that we reset the deck to factory default during the process. either way we are up and running now.
    Mike
  • Jason Tobias
    December 23, 2010 at 10:08 pm
    Had the same problem with a Sony PDW-F1600 and it wasnt the firmware for me. After calling Sony tech support I determined that the format of my disc was 29.97P 422-1080 50mbps and the deck was set to read 23.97 420 1080 HQ. All I had to do was access menu numbers 013, and 031 and change the settings (i had to first unplug it from the MAC to access the menu)
    After changing the settings in menu 13 i had to restart the machine. I also had to eject the disc once it was renamed and put it back in in order for the clips to import.
    but it worked!
    hope this helps someone
  • Jason Tobias
    but it worked!
