Activity Forums Storage & Archiving Tape error
  • Tape error
    Posted by Aaron Duprey on October 27, 2015 at 8:50 pm
    Using Cache-A / LTO-5
    A tape that I’ve just erased is giving me errors when I try to reformat it. Here’s the message:
    _______________
    145 – Table ‘./catalog/file’ is marked as crashed and should be repaired
    SELECT filename,id,parent_id,type,size,mtime FROM file WHERE (toc_id=143 && parent_id=0) GROUP BY (filename) ORDER BY filename,mtime DESC;
    [TEP STOP]
    __________________
    Can anyone decipher this for me?
    Aaron Duprey replied 10 years, 10 months ago 2 Members · 2 Replies
  • Tom Goldberg
    October 28, 2015 at 2:57 pm
    Aaron,
    That message tells you that the Cache-A’s internal database of all catalogs has become corrupted (basically a mySQL error). This usually can be easily repaired by ProMax support or by anyone logging in through Cache-A’s maintenance login. The process is not difficult but any errors could cause bigger problems.
    I recommend that you contact ProMax support to get this fixed, but if that doesn’t work for you and you are comfortable using a command line, please send me an email directly and I’ll provide the commands.
    Tom Goldberg
    TGCS
    30201 Rainbow Hill Rd.
    Evergreen, CO 80439
    mailto:tomgoldberg@gmail.com
    https://tomgoldberg.net
  • Aaron Duprey
    October 28, 2015 at 4:21 pm
    E-mail coming your way, Tom. Thanks.
