Activity Forums DaVinci Resolve Tangent Element working with Sonoma + Resolve?
  • Tangent Element working with Sonoma + Resolve?
    Posted by Steven Moses on March 7, 2024 at 2:00 am
    Do the Tangent Element Panels work with Sonoma 14.3.1 and Resolve 18.6? I have just upgraded OS and my panels son’t seem to work. I have installed Element Hub from the tangent element website. Restarted several times, selected and de-selected the element panels from panel preferences.
    Steven Moses replied 2 years, 4 months ago 1 Member · 1 Reply
  • Steven Moses
    March 7, 2024 at 3:42 am
    This is now resolved. Element still works. From tech support:
    1) Quit all applications.
    2) Unplug all Tangent panels.
    3) If you’re using the Element‐Vs app on a tablet then quit this.
    4) Go to the Tangent folder in Applications.
    5) Run the Tangent Mapper and go to the Help menu and select Reset System.
    6) Quit the Tangent Mapper.
    7) Run the TangentHub‐Uninstaller. This will open a terminal window which will prompt you
    for your admin password. You need to enter your admin password to continue, note the
    letters you type will not appear as you type them.
    8) Reboot your computer.
    9) In Finder got to the Go menu and select Go To Folder…
    10) Enter /Library/Application Support and click Go
    11) Delete the Tangent folder if it exists.
    12) In Finder got to the Go menu and select Go To Folder…
    13) Enter ~/Library/Application Support and click Go
    14) Delete the Tangent folder if it exists.
    15) Reboot your computer.
    16) Now install a fresh copy of the Tangent Hub from the Tangent website.
