Activity Forums DaVinci Resolve Tangent Element problem
  • Tangent Element problem
    Posted by Von Thomas on August 4, 2013 at 4:00 am
    Ok, so I purchased a set of Tangent Elements panels, and now I’m having a bit of difficulty getting them to work with Resolve. I launched Tangent Synapse, all panels show up, I launch Resolve with the Element panel selected in preferences, but all I get is “synapse” in the panel displays.
    OK, I just clicked reset in the Tangent Synapse window, now I have info in the display panels for Tk, Mf, Bt, but Kb is not lit up, nor working, any suggestions?
    Von
    Von Thomas
    DIT / On-Set Dailies Colorist
    David replied 12 years, 7 months ago 4 Members · 5 Replies
  • Juan Salvo
    August 4, 2013 at 4:09 am
    Are you starting resolve while synapse is running? I believe you need to have just resolve run, not resolve and synapse. You may need to reset the elements as your panels. Start resolve, select none for panel, quit resolve, stay out of synapse, then restart resolve, reselect the elements, quit resolve, then reopen resolve. Hopefully they work then.
    color/post/workflow
    https://JuanSalvo.com
  • Von Thomas
    August 4, 2013 at 5:06 pm
    Thank you Juan. I’ve closed Synapse, 3 of the 4 panels are working in Resolve, Tk, Mf, Bt, but Kb, is not working. Kb works in REDCINE X, but not Resolve. Wonder what is needed.
    Von
    Von Thomas
  • Juan Salvo
    August 4, 2013 at 5:25 pm
    you need to enter a function for it on the button panel.
    color/post/workflow
  • Paul Provost
    August 5, 2013 at 7:31 pm
    are you using using a good quality powered USB hub?
    http://www.4Kfinish.com | owner-colorist | Hollywood, CA
    http://www.facebook.com/4kFinish
    Twitter 4kfinish
  • David
    January 29, 2014 at 9:23 pm
    Von,
    I’m experiencing the same problem you describe here. Did you get it resolved?
    Thanks for any help you can share.
    David
    Post Office Editorial
    postoffice@15elm.com
