Activity Forums DSLR Video Tamron Lens on T2i?
  • Tamron Lens on T2i?
    Posted by Bob Tanner on March 11, 2011 at 10:41 am
    I ordered a T2i and I have two Tamron lenses. First is a Tamron SP 28-105mm 1:2.8 and the second one is a Tamron 28-300mm lens 1:3.5-6.3 (Macro). Are they going to work out, or do I need an adapter?
    Zevie
    Phil Balsdon replied 15 years, 5 months ago 2 Members · 1 Reply
  • Phil Balsdon
    March 11, 2011 at 9:30 pm
    Are the Tamron lenses EOS mounts? If so yes they will fit.
    If thet are another brand, Nikon or Pentax for instance you can most likely make them work with a suitable adaptor.
    The 28-105 is a good lens for HDSLR video work. The 28-300 will work but it doesn’t have a constant iris function, which means as you zoom the exposure will change.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
    https://philming.com.au
    https://www.steadi-onfilms.com.au/
