Activity Forums Broadcasting Tally Lights for Panasonic AV-HS400AN
  • Tally Lights for Panasonic AV-HS400AN
    Posted by Frank Wiewandt on February 26, 2009 at 12:43 pm
    Hey All,
    I’m trying to figure out what parts-n-pieces I need to attach tally lights to the studio cams from the Panasonic AV-HS400AN. I was originally going with a Datavideo switcher & they had a system built in. I need to know what actual on-camera tally lights to use as well as cables & “black boxes” needed to make it all work.
    Seems like this should be a simple, straight forward thing but I can’t find any plug-n-play solutions.
    OK, I’ve looked around a bit & maybe there is a low cost solution. Anyone use the Datavideo TB-5 kit that comes with all the “parts-n-pieces”?
    TIA,
    Frank
    Frank Wiewandt – Medina Co. Career Center – Video / Imaging Instructor
    Ted Kazmierczak replied 17 years, 5 months ago 4 Members · 3 Replies
  • Chuck Pullen
    March 4, 2009 at 3:52 am
    Hey Frank, how do you like the 400? I am planning on picking one up myself soon, and I was going to go with the datavideo system, as they seem to be the only ones to sell the all-in-one solution.
    The only other thing I can suggest is what we did at a little TV station I once worked at. I’ll put it this way, you need a power supply, an enclosure, and connectors from Radio Shack, then you need to go to a truck stop where you’ll find dozens of types of 12 volt lights, and pick the one the looks best for your setup.
  • Jamie Elson
    March 5, 2009 at 9:10 pm
    I am aslo thinking of going with the Panasonic for a 4 camera hd studio and wondered if you or anyone else has any problems with audio sync issues… I would also be interested in how you find a tally solution…
  • Ted Kazmierczak
    April 26, 2009 at 2:52 am
