Activity › Forums › Apple Final Cut Pro Legacy › Taking 4:3 Footage and turning it into 16:9…Possible? How?
  • Taking 4:3 Footage and turning it into 16:9…Possible? How?
    Posted by Cary King on July 26, 2005 at 5:19 pm
    Hello,
    I have a Sony VX-2000 which I made the mistake of filming in 4:3 and wanted to film in 16:9. I believe I know how to make this work but I wanted to check from you fine folks if I am going about this correctly. I just don’t want to load the footage in and when it comes time to put it on DVD the people look funny or compressed incorrectly.
    Here is what I think should happen. Digitize it as 4:3 into Final Cut Pro and then ‘zoom’ into the footage a bit and clip off the top and bottom so it matches 16:9…would that work? Is there any better way??
    Thanks for any input offered.
    Nick Brenner replied 21 years, 2 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    July 26, 2005 at 8:55 pm
    You don’t need to “zoom in” at all.
    You may want to move the image up or down to reveal the best part of the frame in the center “16×9” area.
    There are several ways to add black bars at the top and bottom.
    You can use the Widescreen Filter on the actual clip…
    or simply add another Video track above the 4×3 footage on your timeline.
    On it, edit the “Slug” and mask out the center area to the 16×9 aspect/position you want (with Mask Shape > Rectangle > Invert).
    This will allow an easier way to “slide” the image up or down (you’d actually move the clip itself with the Motion tab) and the mask would just sit where it was supposed to be on the track above.
  • Nick Brenner
    July 27, 2005 at 12:13 pm
    First create 16×9 sequence – select anamorphic box.
    If you want it to go from 4×3 to 16×9 and have the image fill the whole frame, then you have to blow up the footage in Motion – Scale – set scale to 133 I think. If you are happy with black bars down the side of an actual 16×9 image then just place it onto a timeline.
    The above is for real 16×9. You may want to merely add black bars to the top and bottom of the 4×3 image in a 4×3 sequence to mimic the look of a widescreen production shown on a 4×3 screen. In this instance you don’t need to scale you video. Add the widescreen filter from under Mattes. Obviously if this is then viewed on a real widescreen TV it will look 4×3 with side bars plus your widescreen bars.
    cheers Nick
    docofilms PAL 25fps
