Activity Forums VEGAS Pro Takes of different length – Can Event Duration change (causing Auto-Ripple) between takes?
  • Takes of different length – Can Event Duration change (causing Auto-Ripple) between takes?
    Posted by Jill Simpson on April 10, 2009 at 6:31 pm
    If my takes have different durations, and the shorter one is added first, when I switch to the longer take, it won’t play its full length.
    If the longer one is added first, when I switch to the shorter take, it will repeat (loop), or freeze on the last frame (if looping is off) until the duration of the longer take is exhausted.
    Is it possible to have the duration change to the proper length when I switch between takes?
    Jill Simpson replied 17 years, 5 months ago 2 Members · 2 Replies
  • John Rofrano
    April 10, 2009 at 8:19 pm
    No. A take is a single event of constant duration. You can add any media you’d like but the event will always be the length of the shortest media file.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jill Simpson
    April 11, 2009 at 1:32 am
    Okay. Thanks.
