Activity Forums Adobe After Effects take an object png and create drop shadow
  • take an object png and create drop shadow
    Posted by Anita Sancha on October 3, 2014 at 1:38 pm
    Hi…
    How can I take an object and create drop shadow onto other objects. without having the shadow appear on the transparent background.
    i.e 2 layers
    cup on saucer.
    cup layer 1
    saucer layer 2
    background transparent
    the shadow of the cup ONLY on the saucer NOT the transparent background layer.
    Thanks for all your help
    Anita Sancha.
    http://www.anitasancha.co.uk
    Anita Sancha replied 11 years, 11 months ago 2 Members · 5 Replies
  • Anita Sancha
    October 3, 2014 at 1:39 pm
    After effects 5.5
    Anita Sancha.
  • Walter Soyka
    October 3, 2014 at 1:45 pm
    Don’t use the drop shadow effect or layer style. Instead, use 3D layers and a light to cast the shadows:
    https://helpx.adobe.com/after-effects/using/3d-layers.html
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Anita Sancha
    October 3, 2014 at 2:03 pm
    Hi…. Thats a solution… but the actual project is large and using lights changes the flat 2D style I hope to keep. Lighting takes it on to a whole new “feel” great though it is I was hoping not to go 3D…
    so would really appreciate a 2D solution if there is one !!!
    Anita Sancha.
  • Walter Soyka
    October 3, 2014 at 2:31 pm
    [anita sancha] “using lights changes the flat 2D style I hope to keep. “
    If you set a layer’s “Accept Lights” property to off (in its material settings, tap AA with a layer selected to reveal), then it will not be shaded by lights. It can still cast shadows.
    [anita sancha] “so would really appreciate a 2D solution if there is one !!!”
    You can fake it with a bunch of compositing:
    1. Top Layer
    2. Bottom Layer (invisible)
    3. Top Layer (Drop Shadow Effect with Shadow Only option, Alpha Track Matte set)
    4. Bottom Layer
    Walter Soyka
  • Anita Sancha
    October 3, 2014 at 2:40 pm
    PERRRRRRFECT 2D solution using the alpha matt… just what I wanted…. internet “KISSSSES” and HUGGS
    Anita Sancha.
