Activity Forums Adobe After Effects Take a circular logo letter and turn it into a straight line using after effects
  • Take a circular logo letter and turn it into a straight line using after effects
    Posted by Ted Stefaniw on November 30, 2018 at 3:46 pm
    This is how I envision the animation. A thick black straight line that will kind of roll up into the “a” logo that should be pictured in the post. The “a” has a perfect interior circle, which is impossible to achieve having the tails come out at the angles they do, but I think that could be handled at the very end with just swapping in the actual logo at the end. I haven’t been using after effects that long, but it certainly seems like it should be possible, any ideas?
    Ted Stefaniw replied 7 years, 8 months ago 3 Members · 4 Replies
  • Mark Doctor
    November 30, 2018 at 8:38 pm
    Draw a path around your final Letter and use the path (mask) morphing feature to create a different shape. Make sure you draw the overlap youself.
  • Ted Stefaniw
    November 30, 2018 at 8:55 pm
    Mark, thanks for the response but I don’t want to morph a straight line into the shape of the logo. Picture that logo, pulled straight, into a line that is the same thickness as the logo, and then I want to create an animation that takes that same line and shows it going back into that shape. I thought I saw something in a tutorial that might work, like drawing a line as thick as the logo and then having that line follow a path made with the bezier tool that followed the shape of the logo.
  • Kalleheikki Kannisto
    December 9, 2018 at 12:41 pm
    You can animate the path of a shape layer any way you want, so make a shape path with no fill and a thick stroke and draw the final shape with it. Then animate the starting point into a line. The motions in between are what make it look good (or not).
    Senior Graphic Designer
  • Ted Stefaniw
    December 10, 2018 at 5:44 pm
    Kalleheikkie, Ill give that a try – thanks for your reply – Ted
