Activity › Forums › Adobe Photoshop › Tag or Not Taged
  • Tag or Not Taged
    Posted by John Landry on September 28, 2005 at 3:45 pm
    I use photoshop cs2 mainly for photos that I use in my video editing software. I was told not to color manage the photos, so I have CS2 set to Off in color management. Everything has worked okay till I got a Epson 1800 printer. So my question is what should I use for a working space that I can use for video and also print a photo that matches my monitor. I should also add that I calibrate my monitor using Spyder Pro. Any help would I would be greatfull.
    John Landry replied 21 years ago 2 Members · 6 Replies
  • Richard Harrington
    September 28, 2005 at 5:32 pm
    Calibrate with the Spyder for your printer when doing print graphics
    Turn color magement off whn doing video grtaphics
    No all in one solution
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
  • John Landry
    September 28, 2005 at 6:38 pm
    This maybe a dumb question but I am going to ask and also try it out myself. If I used Adobe RGB 1998 as my profile then the pictures that I am going to use in my video, could I just make a copy and convert it to NTSC profile, and presto everything looks great!!
    September 30, 2005 at 11:49 am
    there is no ntsc profile
  • John Landry
    September 30, 2005 at 1:35 pm
    I have one that says NTSC 1953 and another that saya Epson NTSC 1953 also found another on the net NTSC RGB 1953. I played around with them and was able to get good results, checking it with the cs2 video out. I am going to burn a disk with the three profiles and check the results on some different T.V.s. Was thinking of maybe picking up a NTSC monitor down the road.
    September 30, 2005 at 1:50 pm
    I repeat… there is no such thing as color management and video… those are approximations and they are worthless
  • John Landry
    September 30, 2005 at 2:07 pm
    My goal is to use CM for everything but video, but if you take a taged file and display it on a T.V. it looks like crap. I understand that it is only a approximation, if you display it on 10 T.V.’s you are going to get ten different results. My goal is to find the middle road as far as video goes.
