  • Posted by Nate Boston on June 9, 2007 at 4:29 pm
    Alright, so I’m using Dreamweaver to make my website. I export the slices and html file from Photoshop. In Dreamweaver I give my table a background color (so I can delete some of the colored slices I don’t want to load), but when I do this, it produces a small 1 pixel line on the right and bottom sides of the table! My page background color is different, so it shows up very clearly! How can I fix this? I’ve gone over the table code by hand and can’t find anything! One thing I did notice is that the line seems to be a file called “spacer.gif”, but I can’t figure out how to change it so it won’t make a small 1 pixel line that I’m getting! Any ideas?
    Nate Boston replied 19 years, 3 months ago 2 Members · 2 Replies
  • Dave Potts
    June 11, 2007 at 10:50 pm
    In your output settings in Image Ready (file – output settings…), make sure you have “never” checked for the spacer cell option under slice options.
    Hope this helps!
    Dave Potts
    Broadcast Communications
    University of North Carolina @ Charlotte
  • Nate Boston
    June 12, 2007 at 1:09 pm
    Unfortunately I’m not using Image Ready, but Photoshop. In the Photoshop export settins, I found the option to never use spacer cells. However, when I open the HTML file it generates in Dreamweaver, it is anything but correct. The images are all over the place!
    I’m thinking there is a better way to do this….
