Activity › Forums › Adobe InDesign › Table of Contents (TOC) problem
Posted by Brandon Little on September 12, 2012 at 7:01 pmHey guys! I’ve just gotten a Table of Contents set up and it works just grand – EXCEPT. A few chapter headings ignore the setup and just put the page number beside them like this:
Chapter Heading4
All the others, except a couple, behave correctly like this:
Chapter Heading……………..4
What gives?
Thanks for your tips. I appreciate any advice.
InDesign CS5
Windows 7, 64bitBrandon Little replied 13 years, 12 months ago 2 Members · 7 Replies -
Brandon Little
September 12, 2012 at 7:20 pmUpdate.
Still not sure WHY it’s doing this, but I can add a chapter heading above the existing one and it accepts it, though editing it seems to kill the workaround.
Looking at hidden characters doesn’t reveal anything, but I suspect it’s there on the chapter headings themselves.
WORKAROUND:
I can just hit a Tab after the name and it pops that pesky number out where it belongs, but if I update the table, the issue will return and I’ll have to fix the TOC again.I wonder why it’s just doing that on a few chapter headings?
Dwayne Smith
September 23, 2012 at 11:07 pmG’day Brandon
Without actually seeing your setup, it sounds like something to do with the way you have your tabs set in your TOC style. Did you set a specific tab placement or just leave it as the defaults?
If it’s the latter, I’ll bet the ones that aren’t working correctly are the shorter chapter names.d.
Brandon Little
September 24, 2012 at 6:16 pmThanks for the reply. No override on the styles and all the headers are fine, except for one or two at random. It seems to be related to the number of characters in the title.
If I make it a longer title, it’s fine. Making it shorter, say less than 9 characters, and it’s not.
A BETTER WORKAROUND: Add a few spaces to the end of a short chapter heading. It adds a few blanks in the TOC as well, but who notices?
Dwayne Smith
September 24, 2012 at 9:21 pm -
Brandon Little
September 24, 2012 at 9:38 pm -
Dwayne Smith
September 24, 2012 at 10:13 pmAah — gotcha — now it’s clearer (and, I’m happy to say, I got it wrong)
Do you have any reason for that first tab at .5? Because that’s where your problem is.
Your second screen grab shows it quite clearly — the page number for “payday” aligns perfectly with your indents for your subheads — both of which are set to .5.d.
Brandon Little
September 24, 2012 at 10:41 pmAh! That’s it. The pesky little .5″ tab. I think that the shorter chapter headings came in within that .5″ line and it threw the page number to the tab, just like it’s supposed to. It just didn’t know WHICH tab.
Thanks, that fixed it…finally.
