Activity Forums Adobe InDesign Table border strokes
  • Table border strokes
    Posted by Beatles on January 19, 2007 at 2:29 am
    I formatted my table border strokes in a color. I now need to return to the table and find out exactly what color I used for the strokes, but when I highlight a cell, the format stroke box only allows me to make a new edit, it does not show what color the current highlighted cell is. Is there a way to find this out? thx
    Beatles replied 19 years, 6 months ago 3 Members · 4 Replies
  • Mike Gondek
    January 19, 2007 at 8:26 pm
    Put your cursor inside a cell and drag to select atleast 1 cell you wish to check your stroke/color.
    Right click and choose
    cell options >> strokes and fills
    Unfortunately InDesign does not allow you to change the stroke color of a table cell in the stroke palete, since they allow you to chaneg the gap color.
    Would also be a good feature if InDesign would allow you to hide your selection when formatting tables so you could see your actual fill color without it being reversed out to abother color.
  • Erica Gamet
    January 20, 2007 at 12:42 am
    On the subject of seeing the changes being made when formatting tables (instead of seeing everything in reverse color): I use the tiling method. Create a new occurence of the document (Window > Arrange > New Window), then choose Window > Arrange > Tile to see the two windows side by side. Make sure you don’t have any other documents open by the way…or you’ll see ALL of the open windows side by side. Choose one of the documents to select your table and make adjustments…the results will show in the other document window. The nice thing is, you can have each window set at a different magnification!
    Erica Gamet
    Digital Dimensions
    https://www.digi-wizard.com/learn
    “…for there is nothing either good or bad, but thinking makes it so.”
  • Mike Gondek
    January 22, 2007 at 7:59 pm
    Thanks that is a better solution.
    Still hoping that they will allow you to hide(Comand H) as in Photohsop, which makes formatting type easier.
  • Beatles
    January 23, 2007 at 1:55 am
    Thanks very much.
