Activity Forums Canon Cameras T4i for low-light action shots
  • T4i for low-light action shots
    Posted by Mark Batisah on May 8, 2014 at 5:56 pm
    I have the T4i and, recently, have had a need to use it to take some low-light action shots. Is there anything I can do to better its performance?
    At present I’m using the kit lens with no flash. I’m under the impression the EF 50mm f/1.8 II Lens might produce better low-light action results; is that true? Also, should I look at an external flash and, if so, what would be appropriate?
    Thanks in advance for dealing with this novice question –
    Mark Batisah replied 12 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
