Activity › Forums › Canon Cameras › T2i footage is way darker than it looks on LCD screen.
  • T2i footage is way darker than it looks on LCD screen.
    Posted by Zack Florance on March 24, 2010 at 3:35 am
    I don’t get it. The footage will look great in the lcd screen and then when I pull the card out and look at it its wayyyyyyyyy darker?!?! What gives? Anyone see this before?
    Paul Del vecchio replied 16 years, 6 months ago 2 Members · 1 Reply
  • Paul Del vecchio
    April 4, 2010 at 9:57 pm
    Your LCD is probably not calibrated correctly. It’s probably set to a really high brightness setting. If you’re using the camera LCD, try knocking it down on brightness, using that little gauge on the bottom so that it tells you where the exposure is. I usually like to expose faces around +1. Maybe right in the middle works too but it depends on the lighting in the frame.
    I’m assuming the T2i has that. I’m using the 7D but I’m sure it has something like that.
    Another option is to get an external LCD like the Ikan VX9 and calibrate that so what you’re seeing is exactly what you’re getting. That’s the best option.
    Paul Del Vecchio – Director
    https://www.triple-e-productions.net
    https://www.pauldv.net
