Activity › Forums › VEGAS Pro › t1i mov files
  • t1i mov files
    Posted by Ken Hawkins on April 29, 2010 at 5:48 pm
    what should i be converting my files to so they can be edited in vegas 9? Ive seen several suggestions from freeware to sorenson squeeze 9 as suggested software, but all these programs have many options as to what type of file you can render to, and many options in each of those files as the settings and parameters. What does sony want the files to be, and what will get me good quality video. Im shooting 1280×720 in the canon
    David Keslick replied 16 years, 4 months ago 3 Members · 4 Replies
  • John Rofrano
    April 29, 2010 at 6:17 pm
    Sony edits most camcoder formats natively. If it won’t edit yours then I would use Cineform.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ken Hawkins
    April 29, 2010 at 7:51 pm
    the canon t1i shoots mov files. i have found several programs that can convert mov to avi or whatever, but i dont know what i should be converting them to, and what settings within that program i should be converting them to. mov files tend to bottleneck in vegas. the stuttering is hard to overcome when your editing. When i converted to avi the quality was very low (but it played without stuttering..i guesss thats something)
  • John Rofrano
    May 1, 2010 at 2:58 pm
    …mov files tend to bottleneck in vegas
    Mov files are NOT a bottleneck in Vegas. I use them all the time in my work. The bottleneck is that your still camera shoots a non-standard video format. If you used a camcorder that shoots HDV or AVCHD you wouldn’t be having these problems.
    As I said in my previous post, you should look into Cineform NeoScene and see if it will convert your footage into Cineform intermediaries. It supports the Canon 5D/7D format so it’s worth a try. Otherwise you can try free converters like AviDemux 2.5 and convert your footage to Lagarith, Huffyuv or MJPEG AVI files.
    ~jr
  • David Keslick
    May 5, 2010 at 10:30 pm
    Another option is not to transcode but rather use DVFilm EPIC with your t1i files to edit in Vegas. You get realtime editing without transcoding.
    EPIC
    Dave Keslick
    DVFilm.com
